[SOLVED] How to choose transistor power amplifier for a signal transmitter from unconventional specifications
Minchuu
Newbie level 5
Hello!
I have a 4vpp signal at 500 kHz that needs to be transmitted at a max distance of 50km. Therefore, it needs to go through a transistor power amplifier that will also drive a 50ohm load (theoretically, the antenna). The bit rate will be 50 kbps. The receiver sensitivity at the end of the 50km distance is -50 dBm.
As a newbie student at this kind of topic, I am at lost how to choose what type of amplifier shall I choose, and what exactly am I designing. I apologize if I sound stupid TT^TT, but I cannot seem to connect how to choose the amplifier and what is the gain needed based from the weird specifications given. Also, everything will only be simulated so I don't need good results in real life, only that it works optimally in simulations.
Any guidance on this matter will be very much appreciated. Also, if you guys have any power amplifier analog circuit schematics that you can share that will do the bare minimum of the specifications, it will also be very much appreciated also.
Thank you very much!
BradtheRad
Super Moderator
Staff member
Minneapolis, Minnesota, USA
You wish to broadcast on 500 KHz which is close to the spectrum of commercial AM stations. To be heard 50 km away those stations need a lot of power going to their antenna, and you'll also need substantial power. However if anyone picks up your signal (or overtone splatter due to unintended distortion) then you might get an unexpected "visit from local authorities". (Of course it depends on legal restrictions in the country where you live.)
It's important for you to get informed as to what's permissible and what's not. Consider broadcasting on the shortwave bands. If you broadcast on 500 KHz I would limit my signal strength to a short distance, say to the next room. And for a brief period, say a minute at a time.
Minchuu
Newbie level 5
Hi! Fortunately, or unfortunately depending on one's view, this project will only be simulated because of the remote learning due to the pandemic. So I need not to worry about permissions because we won't really broadcast in real life. I only need to operate this project on a purely theoretical basis.
danadakk
Advanced Member level 3
If you google "rf path loss & transmission distance calculations" there are a number
of aids on web that should help.
Regards, Dana.
BradtheRad
Super Moderator
Staff member
In general you apply a 500KHz sinewave (carrier frequency) to a length of wire (your transmitting antenna). Normally the antenna does not carry current. Instead it radiates a magnetic field at 500 KHz. I believe the understanding is that the field alternates between positive and negative polarity.
Under the right circumstances, when the signal is sufficient voltage and the antenna is physically built to the right length, or else electrically tuned to resonate at 500 KHz...
A transition occurs from a magnetic field to electromagnetic waves (i.e., photons, in the sense that radio is of a similar nature as light, both being electromagnetic waves).
The antenna consumes current. Photons radiate from the antenna. If it is constructed to be directional then the photons may be concentrated in a beam strong enough to be picked up by your receiver at 50 km distance.
The oscillating circuit needs to be stable at your desired carrier frequency. Often it's based around an LC tank. Common choices are Colpitts, Clapp, Hartley, Pierce.
    Minchuu
danadakk
Antenna V and I distribution, dipole, monopole -
Field distribution -
Regards, Dana.
    Minchuu
Minchuu
Newbie level 5
Thank you for the discussion! I kind of got it, and from my research from the clues you gave me, I think I got was that I need a transmit power of 51 dBm. It does seem kind of a lot, though. Do you guys have any suggestions what topology of transistor power amplifier should I use to achieve this kind of dBm? Especially since my signal is only 4vpp.
FvM
Super Moderator
Staff member
Bochum, Germany
Don't know how you arrived at 51 dBm. R&S field strength and power estimator gives me +66 dBm (4 kW) transmitter power for -50 dBm received power and antennas with dipole gain. These days, class D amplifiers are preferred for high power in medium wave range.
Minchuu
Newbie level 5
I set a link margin of 5dB, so the minimum signal power that the receiver should detect would be -45 dBm. I computed the path loss to be 60.4 dB if 50km is used with 500kHz operating frequency. so the transmit power is -45 dBm + 60.4 dB = 51 dBm.
But of course, I am really not sure about my methodology so you would probably be correct and thank you for the correction! :) I will try to design and simulate a class D amplifier. Very much appreciated!
albbg
Italy
-45+60.4 = 15.4 dBm
that is 1.3Vrms onto 50ohm load, corresponding to roughly 4Vpp, that is your specified voltage. If you can use a generator able to directly drive a 50 ohm load you have to do nothing, otherwise you'll need a transistor stage having gain=1 but able to match your impedance with the load.
Since is a simulated link I supposed no antennas gain and no losses due to cables.
--- Updated ---
All the transmitters I have seen are dark at night and do not produce photons (in post #5).
The word "photon" is related not only to the ligth, but to all the EM waves
Easy peasy
Advanced Member level 5
Melbourne
whatever your power to the antenna, say 1W, the xtor will need to be rated well above this and properly heat sunk and will likely dissipate at least the same. i.e. in his case 1W, thus the power supply to this stage should be at least 3x capable, i.e. 3W in this case ...
BigBoss
Turkey
Obtaining this power level is not an issue but the antenna dimensions are really troublesome.Because
\[\lambda\]=600m
Minchuu
Newbie level 5
-45+60.4 = 15.4 dBm
--- Updated ---
oh, I think I did an arithmetic mistake, thanks for pointing it out. I think I got the 51 dBm because I was confused about the operations involving dBm and dB. 15.4dBm does sound more reasonable. We're not allowed to use generators, so I will probably do a Class D amplifier. But you're right, I'll have to spend effort with the impedance matching.
Thank you for all the help!
