faizanbrohi
Newbie level 5
wireless i2c
Hello Everyone . Well After Building a Audio Transmitter Now i want to transmit Video Signals as well I have found This great IC . it is a VHF Audio/Video Modulator with RF Output level of 82dbuV . and i think if i connect a input of a camera and then connect an antenna at this IC's RF Out Pin and Tune into my TV i would have a Video Transmitter. The IC is from freescale semiconductor( previously Motorola semiconductor).Obviously it will Require RF Amplifier to drive the antenna .
The IC is MC44BS373CA . here is the link https://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MC44BS373CA#orderables
The problem is that it uses I2C Interface and i am new to it . i have the CCS Compiler , i have the software I2C Code but it won't compile. Does anyone have a software I2C Code which is compatible with CCS Compiler. I have decided to use PIC16F84A for my I2C Master because it is small and readily available . however i am making a demo board using PIC16F877A . it has Hardware I2C , but it is bulky and the reason i am not using PIC16F88 is because it is not readily available. So please if anyone has a software I2C Code that is compatible with CCS Compiler , please let me know. the code i found is located herehttps://www.robot-electronics.co.uk/htm/using_the_i2c_bus.htm . but how to compile it in CCS Compiler. it gives a bunch of errors.
