wm168b
The first person to get me this pinout gets 100 points!!!
I have a WM168b internal USB WLAN module from a laptop. I am trying to work out the connections on its flying lead, but it is odd as there are *six* of them. I don't have the laptop unfortunately, or even know what model it was.
I've searched all over for this, but can't come up with anything useful other than it is USB in some way.
I can identify only two onboard ic's, the other part numbers come up blank in Google etc. One is a 39VF010 Flash from SST, the other a SOT23 "7Z14j" - I believe this to be an inverter (**broken link removed**)
I've found ground, thanks to the above ic pinouts.
I think I have found power but I'm confused as it goes into a MOSFET (that's a guess, I can't find the part number but the SOT23 standard MOSFET pinout makes sense) which is gated from another of the flying leads. Maybe just a way of turning it on/off, but I thought that violated USB specs if the data lines are not disconnected first???
The MOSFET-output ?power? then goes into another unknown SOT23, but it matches an adjustable regulator pinout's power input; the surrounding components agree. It also goes to the Vcc of an SOT23 inverter, so I think I'm on the right track.
And that's as far as I've got. Does it do any harm if I connect the data lines the wrong way around, or will I kill something?
It's difficult tracing the connections, since the (unidentified) main controlling ic is a bga package and the board is at least 3 layer.
Any help greatly appreciated.
FoxyRick.
