Hello! Everyone,
I want to measure the variable AC Voltage, which can vary from 0Vrms to 240Vrms (Frequency is 50Hz)
So will the following circuit circuit work?
As i have to measure the 240V at maximum which means 240*1.4142 = 339.411 V = 340V Peak Voltage
So i have to drop down the 340V peak voltage to 5V which is done with the help of Voltage Divider circuit, with R5 = 100k and R6 = 1.5K, and using this i can convert 340V into 5V (340*1.5/(101.5) )
Then i used a diode to clip the negative cycle of the AC signal, I am using 1N4148 diode and it's dropping my voltage by around 1.12-1.18V, is there any other diode which has less Forward Voltage Drop.
So my question is, will this circuit work? Any suggestion.
I am using PIC for measurement and taking samples at every millisecond and after taking sample for 40ms ( 2 complete cycle i will convert these values into VRMS value)
Now I am getting the ADC Count as follow:
0,0,0,0,9,31,52,72,94,243,528,758,913,973,934,798,581,305,10,0,0,0,0,0,11,33,50,70,92,213,502,738,903,971,943,815,606,334,38,0
As you can see there are 5 zeros only but it should be 10, and previously i am getting these value which were as follow:
738,853,865,783,606,359,84,0,0,0,0,0,0,0,0,0,0,26,242,511,719,842,870,797,,633,395,109,0,0,0,0,0,0,0,0,0,0,13,278,543
In circuit i just added this chassis.
Please suggest how can i connect AC circuit with micro-controller.
Any other suggestion.
