Will the hex file for 12F509 work for 12C508?
hassan1980
Full Member level 4
I have a hex file for 12F509 but in my country there is 12C508.
can I use the same hex file for 12C508?
I am waiting your reply
Re: Question about pic
509 has 1024 words of program 41 bytes of data memory.on the other hand 508 has half the program memory and 25 bytes of data memory,but both micro controllers are pin compatible.If ur hex file is within the limit of 508 you can use it as 509 replacement.
Question about pic
Just a point that altought It is pin compatible,
The two microcontroller may have different register types or names. which you must check the datasheet. If that, the program will not work.....Or you just try it see how is the effect if do not want to read that two datasheets.
Please post ur hex file and i ll check if it can be converted. And i can convert it for u also.
PIC ia nothing but a microcontroller
Question about pic
Friend, what you can do is, get a HEX disassembler to convert the HEX code back to ASM source. From there you can verify the REG names, I/O, .... etc. Than, modify the converted ASM file with correct ASM statements and Compile the ASM again to HEX for youe targeted PIC.
