WiFi+Bluetooth Combo
ignition
Junior Member level 1
Hi
I m looking for WiFi b/g/n (should suffice) + Bluetooth 4.0 dual mode combo solutions. Ideally with stacks embedded in solution and available in USB dongle form factor.
However availability in USB form factor maybe rare, so any recommendation of solutions with stacks embedded will be great.
Thanks
Hi
Thanks
You can also try making your own. You can use the reference design as starting point.
TI makes stuff like this.
https://www.ti.com/lit/ds/symlink/wl1837mod.pdf
