palam_rect
Newbie level 3
element thickness
I am designing yagi for 910 Mhz.
I designed yagi using freeware program quickyagi(qy4) and i
am trying to simulate it using nec2 (4nec2).
what i found using simulation is "Decreasing element thickness increasing gain"
Is this correct ?
To increase gain, if i go on reduce thickness, will that have any other impact ?
What's the optimal element thickness for UHF (800Mhz-1Ghz) Yagi ?
(about my design: 4 element yagi, 915 Mhz, element diameter = 4mm )
Regards.
Is this correct ?
Regards.
