I'm going to revive this post for a hypothetical question.
Suppose we CAN build an antenna that is 75km long. What else would require us to modulate speech signals?
So we'd have some type of transmitter, transmitting a direct speech signal at say 1kW.
thats right see previous comment its inductiveWould that be a 1kW audible signal heard over the air? (My guess is no because it's electromagnetic and not instantiating pressure in the air to make sound waves?)
According to the Friis equation, a higher wavelength has less path-loss (it's in the numerator). Does this mean that you would need less equivalent antenna gain on that 75km-long antenna to transmit the same distance as say an FM-radio signal?
Silly hypothetical question, but it got my brain thinking about some of the fundamental physics ...
Thank you for the response. Your example of the hearing loop system was perfect.
Although I think there was some confusion in the way I phrased my questions. Some responses:
1) in response to "Speech signals ARE the modulation":
Yes, technically speech is modulation. But most RF context considers modulation as a means of conveying a baseband information signal, such as analog speech, over a carrier signal. Or in wikipedia's page on modulation as an example: "In telecommunications, modulation is the process of conveying a message signal, for example a digital bit stream or an analog audio signal, inside another signal that can be physically transmitted. "
Perhaps I should have phrased the question as "What else would require us to wirelessly transmit a baseband speech signal directly without FURTHER modulation onto a carrier signal?".
2) In response to "HUH ??? higher wavelength ??? ...":
Yes, wrong term perhaps. I used "Higher" as "of larger magnitude". So higher = larger = bigger = longer ... whatever. Given that, my statement is perfectly correct w.r.t. the Friis equation.
3) In response to "Ummmmm Do you actually know how a radio transmitter works" + "time for you to read some basic books on radio transmitters":
Actually I think it was more just miscommunication with regard to terminology than anything else. Why the hostile tone and unnecessary negative comments? I do appreciate that you provided a technical response though. I've certainly learned to respect the comments of professors throughout my education ... even the arrogant ones.
4) Other:
I'm still curious on the some of the key differences in design between a baseband transmitter and one say for an AM broadcast (amplifier parameters, any other components needed aside from a mixer/oscillator).
But don't fret and no need for more bashing, I'll just go "read a book"
Thanks for being so "welcoming", take care.
