mike_bihan
Full Member level 3
Output stage of buffer
The buffer of d2a circuit need to provide swing capability. The buffer was actually a 2 stage OP-Amp, with unity gain feedback.
The first stage was very typical differential N-pair with Pmos current mirror load. The 2nd stage was a little wierd.
It is consists of one push-pull stage with a current source. The circuit structure was attached in the jpg file.
My question was that why we need that current source?
I was thinking about reason we need one more current source, other than push-pull stage only.
My idea was that the current source will be helpful when the output stage was discharging the output node, make the node begin to discharge before the p-device turn on. However, it also burns current during the hd2a was on.
Can you give me some information?
Thanks!
Thanks!
