why transistors in preamp
asimkumar
Member level 4
Chandigarh, India
i have seen most of the rotating laser receivers(used for grading or leveling) use transistors in preamp section. why do they choose transistors instead of opamp. i don't think they bother about cost and input bias current is not important because there are some op amps with pico amp bias current,so why they use transistors.
i cant upload a circuit, a rotating laser plane(horizontal) detected by a vertical array of photo diodes, signal from the diodes is amplified and detected by a microprocessor, photo diodes usually in reverse bias for high sensitivity, these receivers work with range of 1000 meter with only 3milli watt red laser beam.
Is it so? Well there can't be a serious answer without knowing at least qualitative parameters of the circuit under discussion.
I can imagine many reasons why the the designer chosed transistors for the input stage. E.g. power consumption, form factor, noise, costs, component quotation, tradition and also - technical ignorance. If you are trying to design a new instrument by reverse engineering existing products, the exact answer won't be really important - once you understand the technical requirements. You can chose your own way, and possibly design a better instrument or re-invent the square wheel, depending on your knowledge.
Yes u guessed right am trying to reverse engineer, u can see some equivalent circuits
I would primarly refer to the description and claims to understand the said circuit's purpose. A common base amplifier with or without succeeding stages can be understood as a TIA equivalent. Referring to state-of-the-art for other demanding TIA applications, I expect that usual OP TIA designs can replace it with same or better performance.
You'll find out if you start to calculate actual application parameters.
This circuit relies on the input tuned circuit to reject noise. The designer chose to use the very low input impedance of the common base transistor as a load for his tuned circuit. If he had used a CE amp , he would have had a higher input impedance to work into so he would have needed a bigger inductance/smaller cap to get the same characteristics.
Frank
