Why there is static power dissipation in CMOS ICs due to sub-threshold conduction?
lordsathish
Full Member level 5
Asia
Hi... could any one tell me... why there is static power dissipation in CMOS IC's due to sub-threshold conduction....
static power
static power is camparing with dynamic power which is normally the digital clock switch power.
Static power is the power when the digital circuit is power down. Because of the sub-threshold conduction, there is current following through VDD to GND. That's the static power
Re: static power
Hi could you tell me what is sub-threshold conduction...
static power
When the Vgs of the transistor is smaller than the threshol voltage, the current Ids is not zero, that's the sub-threshold conduction
    lordsathish
static power
that's may helpful
Re: static power
Power consumed when the output or input are not changing or rather when clock is turned off. Normally static power dissipation is caused by leakage current. (As we reduce the transistor size, i.e. below 90nm, leakage current could be as high as 40% of total power dissipation).
Check this link too
static power
Remember one thing, in small geometries, the treshold voltage isn't decrease so much as suppl voltage, therefore the static power dissipation increases, because the gates could be made high impedance like in techologies with larger suppl voltages. quiesent currents in gates in power dowb node could be in A range for large digital chips an low voltage and small geometries.
