Register Log in
Why S22 curve is like this
circuitking
Full Member level 4
Hi, I am working on a triple stack amplifier. I just baised it, all transistors are in saturation, and wanted to check S22. The resistances are negative. What could be wrong. I am not sure If I can share the netlist outside for this technology. Also Is there any particular method (Like defined formulas) to provide how much bias voltage at the input of all the three transistors (Say M1 is the bottom transistor to which I give signal. Bottom M1 -> M2-> M3 (Top)) such that all of them will be in saturation. I know how to choose the gate voltage at M1 but I am not exactly sure how much gate voltage tp be given to M1 and M2. Thanks
Anyone know any other good book for stacked transistor amplifier other than Millimeter-Wave Power Amplifiers by Jaco du Preez, Saurabh Sinha
pancho_hideboo
Advanced Member level 5
Real Homeless
circuitking
Full Member level 4
I want to have positive resistances. I am wondering how to make it possible
circuitking
Full Member level 4
You amplifier may be unstable..
Yes it is, but If I have to keep degenerative inductor it needs to a huge value. I tried with small inductance values but still it is unstable.
BigBoss
Turkey
There are methods to stabilize an amplifier such as connecting a resistor at input and/or at output.A negative feedback may also stabilize the amplifier..
circuitking
Full Member level 4
I have seen in a book, a capactior is also used. I am still wondering how bias is provided when capacitor is kept in the signal path as shown in the figure.
circuitking
Full Member level 4
Simply bias circuitries are not showed.
That’s all.
I know that bias is not shown. If at all bias is connected, where should it be connected?.
Anyway, I found out where It should be connected without disturbing biasing.
Toggle Sidebar
