module CRC5D1_test_bench;
parameter integer initial_value=-1;
parameter integer poly_width=5;
parameter integer maximum_no_of_errors=3;
parameter integer data_length=10;
reg data;
reg clock=0;
reg sync_reset=1;
reg hold=0, receiver_hold=0;
wire [poly_width-1:0] crc_sender,crc_receiver;
reg done=0;
reg error=0;
integer i,test_loops,error_counter;
wire receive_data=data^ error;
CRC5_D1_Module #(.initial_value(initial_value),.poly_width(poly_width)) crc_tx( .clock (clock),
.data(data),.sync_reset(sync_reset),.hold(hold),
.crc(crc_sender));
CRC5_D1_Module #(.initial_value(initial_value),.poly_width(poly_width)) crc_rx( .clock(clock),
.data(receive_data),.sync_reset(sync_reset),.hold(receiver_hold),
.crc(crc_receiver));
always #10 clock=~clock;
initial begin
#5;
test_loops=0;
//Test 1 Make sure no crc error occurs
repeat (100) begin
test_loops=test_loops+1;
if (test_loops%100==0) $display("Test Loops=%d",test_loops);
sync_reset=1;
@(negedge clock);
@(negedge clock);
sync_reset=0; hold=0;
for (i=0;i<data_length;i=i+1) begin
data=$random;
@(negedge clock);
end
hold=1;
for (i=0;i<poly_width;i=i+1) begin
data=crc_sender[poly_width-1-i];
@(negedge clock);
end
done=1;
if (crc_receiver !==0) $display("Miss Detection or Programming Error");
@(negedge clock);
done=0;
end
//Make sure crc error occurs
test_loops=0;
repeat (100) begin
if (test_loops%1000==0) $display("Test Loops=%d",test_loops);
sync_reset=1;
@(negedge clock);
@(negedge clock);
sync_reset=0; hold=0;error_counter=0;
data=$random;
if (i==0) begin
error=1;//We add at least one error.
error_counter=error_counter+1;
end else begin//Limit maxinum no of errors
if (error_counter <maximum_no_of_errors) begin
error=$random;//$random error addition
end
end
@(negedge clock);
end
hold=1;//Stop CRC generation in sender
data=crc_sender[poly_width-1-i];//CRC polynominal are sent
@(negedge clock);
end
done=1;
if (crc_receiver ==0) $display("Miss Error Detection or Programming Error Test Loops=%d",test_loops);
@(negedge clock);
done=0;
end
$finish;
end
endmodule
