First understand, lower the frequency more the distance it can travel with given power.
uplink--> when handset transmit-- Battery powered
Downlink--> when DCS transmit-- Mains powered
now , since lower frequency transmitted by the handset ,it can go to higher distance with low power. low power is important bcoz' it's battery power equipment.
And for downlink the frequency is higher hence need more power to travel larger distance but power here is not a problem bcoz' normelly DCS is mains powered.
I agree with Vfone that FSL is not differing much even if u take extreme case of 800MHz(uplink) and 960MHz(downlink) than the difference is 98.07dB-96.48dB ~1.5dB it's nothing.
But may be in initial development of mobile communication , when battery was not so advanced as now. They borrowed the idea from the satellite communication. I am not sure.
