[SOLVED] Why is Isolation provided at the boundary of the power supply PCB ?
vikasveshan
Member level 2
Hi All ,
I wanted to know the reason behind the isolation provided at the boundary of the Power supply PCB .
1> Should it be Provided on both the layers of the 2 layer PCB ?
2> which is the better isolation Earth isolation or the Ground isolation ?
Regards !!
V V
Not actually a clear question, I fear. It would be helpful, if you refer to a particular instrument design. "Isolation at the boundary" can mean a lot, e.g. reinforced isolation against SELV circuits required by safety standards. Also the difference between "Earth isolation or the Ground isolation" isn't obvious.
Actually i was looking PCB layout of some Power supply for PLC .
On the Boundry of the power supply PCB there was EARTH Isolation provided .
Just wanted to know the purpose behind that isolation .
Regards !!
V V
---------- Post added at 15:31 ---------- Previous post was at 14:43 ----------
By isolation i mean the Solid trace surrounding the PCB edges and that solid trace is connected to the EARTH point .
regards !!
V V
I don't think, that it's a relevant means related to a known safety standard. It may help to reduce EMI.
