Why is differnt S parameters between HFSS and ADS?
John_li
Full Member level 5
Hi friend,
Anyone has experiment about different s parameter between HFSS and ADS?I simulated a passive filter in HFSS,and export the S parameters into ADS,I found the parameters are quite different.Can anyone share us the experience how to get the consistent parameter?
Thanks
Can you show us your setup & results?
How much difference you have found?
    John_li
There shall be no difference analyzing an exported S-parameter file by a different CAD simulator.
I understand to be slightly differences in results when doing separate simulations, for the same circuit, using different CAD simulators.
    John_li
Thanks,friends.i find the root cause.as what both of you said,it is the same.
