Why interrupts are Active low???
kpk
Newbie level 5
Kindly post any documents regarding resets.
if you see the reset circuit you can solve it by yourself.
The reset is implemented by PMOS so in order to make it effective it should be low.
or in traditional RC based circuits it can be low or high depend on the place of the reset switch
Hi KPK,
Attaching a pdf related to reset usages in SoC design. Hope it helps...
active low reset is used to reduce the power consumption
