Why in SAR systems array antenna are used and reflectors not
Catallo
Member level 3
SAR question
Why in SAR systems array antenna are used and reflectors are not?
Re: SAR question
I am assuming you are asking about synthetic aperture RADAR antennas. In general they are one directional. Otherwise they would give ambiguous results by adding the images from both sides. On aircraft they are on the sides of the fuselage and only image to one side.
Re: SAR question
I think -
because slot array antenna is electronically steered and thinner.
Re: SAR question
Dear catallo,
while it is true that phased array are often employed for SAR applications, expecially for they steering capability in spotlight-mode, it is not true that reflector cannot be used in SAR.
An example of SAR reflector is embarked on the Cassini spacecraft that btw is arriving to Saturn in these days.
Bye
Re: SAR question
satellite, do you have any material on reflector antennas for SAR
Re: SAR question
Satellite, i would be interesten in the Cassini space mission,
do you have anything?
SAR question
Another SAR with a reflector antenna was the Magellan mission to Venus (1990). The same reflector was used for the SAR and for communications with earth.
Z
