What is "an ordinary mic"? it is not a dynamic coil and magnet mic, it is a common electret mic that was in a broken cell phone.o_wsam said:-is the mic is any ordinary mic, and what about its impedance matching?
Of course.-(R5=470)&(R7=220) is it in ohm?
I used 1mm enamelled wire from a speaker's crossover network. See my sketch.-for the inductance (0.1UH),what type of wire used for winding,and what its diameter?
It is a "low dropout" 5V regulator that still works when the battery voltage has dropped to 5.5V. All semiconductor manufacturers make 5V low dropout regulators.-what is the (LM2931A 5.0)?
It is 1/4 wave and is just a piece of wire 80cm long. If it is shorter then the range is less.-what type of antena should I use?,would the antena of ordinary radio work?
It is extremely simple and uses the same circuits as many other FM transmitters.-do you have an analysis for the work this cct.?
