liberal
pll drift
My synthesizer is 880MHz with ADF4113,the reference is a 10MHz OCXO,and the N is 88.
1.when i test the OCXO with spectrum analyzer,it is 10.000002MHz,i think if locked,it will output 880.000176MHz,but the spectrum analyzer is 880.000471,why?
2.when i reduce the SPAN to 1kHz,i see the frequency will drift slowly,i will be 880.000490MHz after half an hour(maybe it will drift with time,but i don't measure),why drifting?and when the loop bandwidth is 10KHz it drift quicklier and farther than 100kHz loop bandwidth why?
3。when vco output is 880.000490MHz, divided by N=88 ,it is 10.0000056MHz,if the PFD detect one or some Hz?
