I create a module then synthesize it.Everything goes well.
But when I call it in upper block,my synthesis tool tell me there is some logic cannot be synthesized.
I do all my work in ISE6.3i.
Why does this happen?
And how should I deal with it
thx
yeah
i write a frequency division module(name it "pre_freq_div") in order to output different frequency related to the division coefficient input,and the coefficient may be large(14-bit).
this module get synthesized correctly independently. i also simulate it in modelsim se 6.0, the wave is perfect, i think.
But when this module is getting into use from top level design,the systhesis tool tell me:
Synthesizing Unit <pre_freq_div>.
Related source file is pre_freq_div.v.
Register <counter> equivalent to <freq_out> has been removed
ERROR:Xst:739 - Failed to synthesize logic for signal <freq_out>.
ERROR:Xst:1431 - Failed to synthesize unit <pre_freq_div>.
always @ (posedge clk)
begin
if(_reset==0)
begin
freq_out=0;
counter=0;
end
else
begin
if(div_coef==14'b0) freq_out=0;
else
begin
if(counter!=div_coef)
begin
counter=counter+1;
freq_out=freq_out;
end
else
begin
counter=0;
freq_out=~freq_out;
end
end
end
end
everything looks ok.. cept of the _reset thing.. im not sure if thats valid or not.. cause i never use that naming style.. (perfer rst_n)..
i don't have anything installed to compile/synth it.. to see what it says.. but i cleaned it up to how i would format it.. try it and see if that makes a difference.. if so it could just be syntax..
im assuming your instantiating that module.. so it could be something on the next module up..
Here I have modified ur code aq little bit. Hope you were not using
freq_out as clk for other modules. I changed this signal to single clock
pulses, use this one as clk enable in other modules!
Hope this sloves ur problem.
module pre_freq_div(clk,
reset_n,
div_coef,
freq_out);
input clk, reset_n;
input [13:0] div_coef;
output freq_out;
reg freq_out;
reg [13:0] counter;
always @ (posedge clk) begin
if (!reset_n) begin
freq_out <= 1'b0;
counter <= 0;
end else begin
if (div_coef == 14'b0)
freq_out <= 1'b0;
else begin
if (counter == div_coef) begin
counter <= 0;
freq_out <= 1'b1;
end else begin
freq_out <= 1'b0;
counter <= counter+1;
end
end
end
end
endmodule // pre_freq_div
