T
treez
Hello,
The following article states , on pages 15 to 16, how the sync FET of a buck converter can be spuriously turned on when the top FET turns on..
“MOSFET Selection to Minimize Losses in Low-Output-Voltage DC-DC Converters”.
https://www.fairchildsemi.com/techn...es-in-Low-Output-Voltage-DC-DC-Converters.pdf
Surely a good way to mitigate this is to use MOSFETs with higher Vgs(th). After all, if the Vgs threshold voltage is higher, then the spurious upsurge in VGS has further to go before it can turn the FET on. So why does the document not mention that using FETs with higher Vgs(th) is a good way of mitigating this problem? Also, with 60V Vds rated FETs and below, why are they mostly having such low vgs(TH) of 1.2-2V? For example, the Infineon NFETs in flat QFN style packages almost all have logic level Vgs(th) of 1.2-2V. –Such a low Vgs(th) doesn’t help in reducing the spurious FET turn_on mentioned. –Especially at high temperature where the Vgs(th) gets even lower still.
