Why antenna gain is always in negative?
brahma
Full Member level 1
why antenna gain is always in negative???
antenna gain??
Antenna gain is not always negative. There are many cases (Zagi's and microwave dishes for starters) where the antenna gain is positive.
Re: antenna gain??
It may depend on the reference used... I mean if your looking at a radiation pattern you could have normalization and then obtain a zero gain...
this could be another case...
Pay attention also to this things.
hope this helps. ciao
Re: antenna gain??
gain will be always a positive quantity.reciprocal of gain or negative polarity for gain gives a new parameter called as attenuation...hope it helps
