May 21, 2004 #1 Y yykk Member level 1 Joined Aug 29, 2003 Messages 39 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Location Hong Kong Activity points 279 Hi, Who have the waveguide filter example ? if yes, Can u give one for me ???
Jun 19, 2004 #2 S springf2000 Full Member level 6 Joined Jun 13, 2004 Messages 381 Helped 20 Reputation 40 Reaction score 2 Trophy points 1,298 Activity points 2,500 WHAT IS THE PROBLEM WHEN YOU USE THE HFSS to simulatie the E fileter
Jul 30, 2004 #3 B bhgaurav Junior Member level 3 Joined Jul 29, 2004 Messages 29 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,283 Activity points 233 I am also doing a similar simulation. My design works fine when i simulate in ku band. but when i setup a new design for ka band the pass band is not visible. does it has to do with mesh refinement. please comment
Feb 26, 2005 #4 A amicloud Full Member level 2 Joined Oct 11, 2004 Messages 138 Helped 4 Reputation 8 Reaction score 2 Trophy points 1,298 Activity points 1,100 YOU SHOULD CONFIGURE THE MESH MANUALLY,OR YOU WILL FIND NO PASSBAND.
Feb 27, 2005 #5 I itaifrenkel Full Member level 2 Joined Oct 9, 2004 Messages 147 Helped 36 Reputation 72 Reaction score 17 Trophy points 1,298 Location Israel Activity points 1,859 How big is your filter in lambdas ? How wide is your band pass ? If it is not big you can use lambda refignment instead of mesh operations. Set lambda refinment to 0.1 and number of adaptations to 1. Itai
Mar 8, 2005 #6 B bhgaurav Junior Member level 3 Joined Jul 29, 2004 Messages 29 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,283 Activity points 233 does anyone has the example for this
Mar 8, 2005 #7 B biff44 Advanced Member level 6 Joined Dec 24, 2004 Messages 5,046 Helped 1,376 Reputation 2,748 Reaction score 1,056 Trophy points 1,393 Location New England, USA Activity points 37,902 I just have to ask, after you build and test your Ku band filter, does its performance match the ADS prediction, or is it off 30%?
