who know the s-parameter of the 2SC3356,I'll design a LNA
zhonghua_li
Junior Member level 2
2sc3356 model
I'll design a FM LNA(fom 76MHz - 108MHz),use 2sc3356
there are only s-parameter of the 2sc3356 form 200Mhz-2Ghz in the datasheet of 2sc3356.
Re: who know the s-parameter of the 2SC3356,I'll design a LN
If you want S parameter for frequency (76 to 108MHz) then you can do S parameter simulation in ADS.
Just make nonlinear model of the transistor you want. Provide the biasing condition as given in .s2p file or the datasheet you are using.
You can find nonlinear model in your datasgeet.
Abhishekabs
Added after 33 minutes:
see this image[/img]
I used do S-parameter simulation with the lib component of 2sc3356.
but the result is very different form the datasheet described
Have you checked the bias?
There will be some difference between S parameter given in data sheet & S parameter obtained by S parameter simulation if you use non linear model or lib file .
If still you did not get the result then you can always predict parameter by method of extrapolation or interpolation.
