Who know a IC which can be read by DSP and output to RS232?
ic02
Newbie level 1
Newbie level 1
Please tell me the type of the IC!
Hi ic02,
what do you want to do? Add a serial port to yout DSP? In this case, you
can use a UART like the 16C550 (National, includeing FIFO). This chip has
a 8bit databus and include 8 registers that you can access from your DSP.
The other side you need a digital to RS-232 pegelconverter like a MAX232.
The connection of the UART to the DSP depends heavily on the DSP you
are using. Mostly you have to insert wait states. Which device do you use?
Greets
To:mr_ghz
I have already found the IC ST16C1450,but I can't buy it in china!
Can you suggest me the other IC which has the same function of 16C550?
Hi ic02
I know following types:
16450 or 16C450 from National, ST, ... is a UART without FIFO buffer
16550 or 16C550 from National, ST, ... is a UART with FIFO
from Texas Instruments there are many other types, but I don't know
which you can buy in your contry...
Another possibility is to use a shift register or a CPLD (to build your own
UART).
