No it will not work, especiallz on such a big diferrence between frequencies...kender said:There are mass produced baluns for hundreds of MHz. I'm looking for a balun for 100kHz. Will a balun rated for higher frequency work at a much lower frequency (assuming the same current)?
How can I calculate the balun parameters? I have a receiving antenna with biult-in LNA that outputs a differential 100kHz signal. I want to convert it to single-ended. Right now it's done with an instrumentation amp (the low frequency allows it), but I think that balun is a "cleaner" solution. I have never designed magnetics before. Could anyone help me design a balun or point me to the article that describes how to design one?sinip said:No it will not work, especiallz on such a big diferrence between frequencies...kender said:There are mass produced baluns for hundreds of MHz. I'm looking for a balun for 100kHz. Will a balun rated for higher frequency work at a much lower frequency (assuming the same current)?
Do you mean the kind of transformer used in power supplies to step down 220AC? If it's not too much hassle, could you tell me a certain transformer model that would work?jallem said:For 100 KHz a trasnformer will do the job
