who can tell me? ! thanks! urgent!!!!
stocking
Member level 5
Member level 5
who can tell me how I set the environment variables of $ynopsys DC on the worksti0n with $olaris system!? thanks! I know there is the soft of $ynopsys DC on worksti0n, but I cant invoke it. pls expert teach me , thanks !!!!
you can see the sold document. you need set home directoy and library directoy, bin path .license file etc.
for csh try this (just like)
setenv SNPSLMD_LICENSE_FILE 26585@licsvr
setenv SYNOPSYS /eda/synopsys/solaris/syn200x.xx
set path = ($path $SYNOPSYS/sparcOS5/syn/bin)
You may also try this
setenv LD_LICENSE_FILE $license_file (for license setup)
you need set the environment variable as follow:
LD_LICENSE_FILE or SNPSLMD_LICENSE_FILE for the valid license
path for the searth the executable file.
LD_LIBRARY for the library patch on the tool
in csh
set LM_LICENSE_FILE 5280(tcp_ip port )@lic_server
set SYNOPSYS_HOME ( or SYNOPSYS ) your_install_dir
you can try with the setenv DISPLAY ..................(the host number of the machine)
Hi ,
You must start up a license server before you begin to use the tools. Have you correctly setup the license server?
Thanks.
Lsong
