Currently i am Working on Autoclave. So i Need to select a pressure sensor for reading the
pressure maximum range should be 4 bar. But i am bit confused about pressure types.
I have to measure the pressure which is going to generate inside of the chamber.
What kind of pressure sensor i need to use?
whether its absolute pressure / differential pressure / gauge pressure ?
The differential one could give the ability for the equipament to operate even at regions at higher altitudes. There is the 'Motorola' MPX series which is largely utilized in various applications which should suffice.
Anyway, pressure is a secondary measure, used more for safety purposes, being the temperature the critical factor to be considered in order to ensure proper sterilization during specified time, but you are certainly aware of that.
what kind of pressure sensor is using in a steam sterilizer
Hello, experts
I need to measure the pressure of a steam sterilizer. maximum temperature will be 250 degree Celsius. So what kind of pressure sensor i should use for this. gauge/absolute/ or any other?
and the sensor's maximum operating temperature should be 250 degree Celsius.
please suggest a proper sensor for me?
