Apr 20, 2009 #1 F fnx7 Junior Member level 2 Joined Apr 19, 2006 Messages 24 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,443 50~860MHz VGA?? Which part of variable gain amplifier can be used in this field? spec: frequency band: 50~860MHz impedance: 75 Ohm OIP3: 38dBm gain maximum:at least 15dB gain adjust range: 20dB Thanks
Apr 21, 2009 #2 Mazz Advanced Member level 2 Joined Nov 3, 2001 Messages 674 Helped 131 Reputation 262 Reaction score 50 Trophy points 1,308 Activity points 5,463 50~860MHz VGA?? I don't know any part with exactly that specs. Maybe a solution could be the use of an attenuator+VGA+PA For example: 10 dB attenuator +10 to -10 dB gain (19 dBm OIP3 at max gain) +20 dB PA (>40 dBm OIP3) Overall: max gain=20 OIP3=38 dBm A starting point could be MAX3538 that has 20 dB control range, max gain 10 dB and output IP3 of about 19 dBm at max gain. It will be a very power hungry circuit, I suppose. Feasible? Mazz
Apr 22, 2009 #3 F fnx7 Junior Member level 2 Joined Apr 19, 2006 Messages 24 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,443 Re: 50~860MHz VGA?? Thanks Mazz
