Micro Lover
Member level 2
hi everyone
i want to make a Universal-Digital-Clock, very user-friendly , one master clock, and several slave clocks, the master clock will send data and slave clock receive that data and will display it, these both functions are in one Code, i mean in one IC, so just set one pin as High or Low for Master Or Slave, and it will also use as a timer, common Anode and cathode selection, and some more functions, I used 89c51, but the size 4KB is full. And I want some more functions, like Alarm, Calenders(2 or 3, depending on memory), and temperature in one IC. Is there any IC having more Memory? or I use 2 ICs or more?
