techie
Advanced Member level 3
a dc series motor is best suited for driving
I need to drive the X & Y axis of a shaft grinding machine using a servo motor. The torue required is equivalent to a 2-3HP ac motor. Since I cant use an AC motor for this due to jerky and intermittant load and high startup torque, what is the most cost effective solution for this application. A DC motor, a stepper motor. Is it possoble to use the motor used in hand drill machines. They are quite high torque and suited for jerky and intermittand loads
