Which is better with cadence IC5 suse linux or redhat fedora
khouly
Advanced Member level 5
EGYPT
suse linux or red hat
i want to know , which is better with cadence ic5 suse linux or redhat fedora or redhat 9
thanks
for i know, rh9 cann't install ic5. but ic5032 is ok.
Re: suse linux or red hat
I installed cadence on Suse 9 without problems
It seems that IC 5 and specially spectre, works better on SuSE than redhat however, I have personally used SuSE for a while and then I came back to mandrake. Want to use IC5 only? it is ok but if you want to use linux for more tasks then I do not suggest it.
RH 9 is not stable, SuSE is not good, so i suggest to use RH 8.
_________
ShOaiB
RH9/FC1 actually are ok for some major EDA tools, such as IC5032, Nanosim, modelsim, provided that the system is configured appropriately.
ShOaiB,
Why do you think that SuSe is not good? I have been used it to layout creation, extraction and simulation without problems.
Thanks
RedHat7.2 is the best Platform for IC50.
suse has better support
Bottomline ..... SuSe is the best for IC5.
RH can't come anyway near it in stability ...
I have used both SuSe and Redhat for 3 years for various EDA purposes and RH has always sucked one way or the other.
Use IC5 on SuSe only. Period.
I’m trying to install cadence 5033 on suse 9.0 (AMD64), and I’m having a problem when I try run the configure script to setup and launch the license daemon. Here is the message I get in the log file:
Started cdslmd (internet tcp-port 32768 pid 2378)
FLEXlm version 8.4a
Can’t get date information from 600
Cannot open daemon lock file
Somebody knows what’s wrong with my system? (Apart from that every thing looks fine, and I’m able to run icfb on the machine)
Thanks!
what about the rest of eda tools (on suse/rh)??
like sy$/cad$?
