blooz
Advanced Member level 2
hi
Hi
Designing a Motor/Diesel Engine Control System ...
the Require ments are
1.Electric Motor Should be Driving When the velocity is lesser than 15 Kmph
2.If velocity is greater than 15 Kmph the motor Drive is turned off and a Diesel engine is Started ...
3.If the speed of the Drive by Diesel Engine Comes Below 15Kmph with +/-10% tolerance Motor Should be turned on and Diesel turned off.
The Graphical Description is given below ....
Is it Better to use a Schmitt trigger or Go for Window Comparator .......But when Using Window Comparator the logic generated is whether the speed is inside tolerance range or not .....It's not sufficient to control the motor .....Could you help please ...
![](https://obrazki.elektroda.pl/51_1296289278_thumb.jpg)
Hi
