Where to get SDC files?
p_shinde
Full Member level 5
tokyo
hi,
what all r the sources to get the sdf file?
thanks,
Prasad
Re: SDC sources
if you need sdf..
sources: .lib file containing timing information about standard cells
.v netlist file of your design..
if you need SDC
sources:timing constraints..
tools:synopsys..
Re: SDC sources
Is it possible to generate this SDC file within Cadence to be used for Encounter?
Thanks.
Edit: Nevermind I came across the build gates tutorial.
SDC sources
you may use a commant as
write_sdf *.sdf
in the Design_vision.
Re: SDC sources
You may also dump sdf file after P&R.
e.g., in Astro, "ataDumpSDF"
write_sdf *.sdf
