Hi-Q
Junior Member level 2
Hey,
For most of the SMD components we use, the manufacturers provide recommended footprints (pad layout geometry).
I assume they were designed to offer optimum soldering results with a high margin with various surface finishings on components and PCB, a wide variety of processes like convection heating, infrared heating, soldering in air, nitrogen, using vapor phase soldering and so on.
Sometimes there are situations where PCB space is extremely scarce and in order to fit all the required components onto the PCB it is necessary to sacrifice some of the above mentioned margin.
I believe that many of us at least sometimes have that problem and so I wonder if someone knows how the pads for certain SMD components can be miniaturized without running into too many problems with the reflow soldering.
As an example, I have an 0805 pad layout with the pads being 44 mil long and 50 mil wide whth a center to center spacing of 80 mil (free space between pads 36 mil, overall length 124 mil).
Then I needed a shorter footprint to fit a 0805 resistor into a gap between other components but at the same time allowing to route three tracks under the resistor with a 6mil technology (but 7 mil pad to track spacing because of the solder mask).
In order to be able to place the resistor I needed to make the pads shorter (32 mil) and the center to center spacing to 76 mil (free space between pads 44 mil, overall length 108 mil).
This one is not yet tested, but if the resistor is actually required and populated I can report on the results.
Now I am curious if some of you have tested miniaturized footprints and can give me hints on working geometries.
I'd be especially interested in 0805, 0603 and 0402 footprints and shrinked SO packages like SSOP, TSSOP, VSSOP, MSOP, µMax, SC70-5 and SC70-6 and similar packages.
Regards,
Hi-Q
P.S.:
I know that one can use smaller components if space is scarce, but not all components are available in the packages we'd wish for.
Regards,
Hi-Q
P.S.:
