Patrick520
Newbie level 6
Hi. I am reading a book, Designer's guide to spice and spectre.
In the page 36 of that book, there are lines of words like below:
Carefully check all parameter values to assure they(parameter of component) are reasonable. Use the list and delete the nomod options with SPICE
to get a complete listing of the parameter values. Spectre au-
tomatically checks the parameter values for you if you use the
+param command line option. The list of reasonable valu
are kept in a file provided with Spectre, and so can be modi-
fied to suit your situation. Use the Spectre info statement
with what=all for a list of parameter values if you would like
to check the parameter values by hand. This is done quickly if
extremes=only is specified, in which case Spectre only prints
the largest and smallest values specified for each parameter.
My problem is that I cannot find the "info" tab in ADE of IC5141.
Where I can set the "info statement" like the describing above?
---------- Post added at 22:48 ---------- Previous post was at 22:46 ----------
And, I also cannot find the "+param" in the ADE?
