Where can unions and structures be used ?
naresh850
Full Member level 3
Can anybody tall me where union can use and where structure can use with example.
where union can use
Take a look
I don't want to repeat myself.
Cheers.
where union can use
Structure is a method of packing data of different types. A structure is a convenient method of handling a group of related data items of different data types.
example:
struct lib_books
char title[20];
char author[15];
int pages;
float price;
Union:
Unions like structure contain members whose individual data types may differ from one another. However the members that compose a union all SHARE THE SAME STORAGE AREA within the computers memory where as each member within a structure is assigned its own unique storage area. They are useful for application involving multiple members. Where values need not be assigned to all the members at any one time.
where union can use
con u give me the name of perticuler application for union use
Re: where union can use
variables of same type can be defined in a structure.
Variables of different type that can share the same physical memory can be defined in union.
It is better to read some C text for more details.
where union can use
Just look in any header file from the Pic30 tools c compiler for a Pic30, Pic33, Pic24 micro.
Most ports or registers are defined as bit fields and also as ints.
You can clear a port by writing 0 to the int or set individual bits by using the bit fields.
They share memory.
Unions are also good when ram space is limited.
Beware though, they are not fully portable.
