The OpenCores54x (OC54x) DSP core is a cleanroom implementation of a popular family of DSPs designed by the No.1 DSP supplier from the southern part of the US.
The core is designed to be software compliant with the original Texas Instruments C54x DSP. However, the core is not designed to be 100% compatible with the TI's C54x chips. The core features some extension and improvements over the original design, which make it not-compatible. Also, partially caused by the structure choosen, partially to not completely compete with TI, some operating modes and hence opcodes are not supported. See the compatibility section for more detailes.
Features
16/32, dual-16 bit DSP core
4 Wishbone compliant external busses
highly pipelined for high performance
Up to 5 operations per cycle
structural & opcode compatible with TI's C54x family of DSPs
First synthesis results: >40MHz in FPGA, >300MHz in .18u
Finished:
CPU
ALU
MAC
Barrel Shifter
Compare Select Store Unit (CSSU)
Auxiliary Register Arithmetic Unit (ARAU)
ToDo:
Data Address Generator
Program Address Generator
Instruction Decoder
Tools
Texas Instruments C54x Code Composer Studio or C54x compiler/assembler/linker
GCC (GNU binutils 2.11 and later). Use tic54x as the target (--target=tic54x)
Compatibility
Listed below are known issues between this implementation and Texas Instruments C54x DSPs.
CMPT is not supported.
The compatibility bit is not supported. As a result ARP is always set to zero.
EDB is 32bits wide,
The EB data bus is 32bits wide to support single cycle 32bit write accesses. Long words are always written in 1 cycle. In contrast to the C54x there's no difference between even and odd word addresses. The MSB is always written at the higher address.
