usman_mahfooz
Member level 2
When bypass capacitors are removed and transmission line is open and RF is coming out with only 3 dB isolation. Following image shows what i am trying to say. Can somebody comment how it's possible. Is it because of coupling?
f=3 Ghz
Circuit is on a PCB substrate and pcb is lightly tightened on the base of a flat heat sink.
Another thing is when i press different poins on the pcb etched are the response changes at the output by 2 --6 dB.
f=3 Ghz
