What's wrong in this C code?(ATMEGA32A)
panda1234
Full Member level 2
Full Member level 2
I want to determine duty cycle of signal (for sensors,etc) so i write below code but when i simulate it into Proteus i don't get result.
why?
PHP:
This program was created by the
CodeWizardAVR V3.12 Advanced
Automatic Program Generator
© Copyright 1998-2014 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project :
Version :
Date    : 6/19/2015
Author  :
Company :
Comments:
Chip type               : ATmega32A
Program type            : Application
AVR Core Clock frequency: 1.000000 MHz
Memory model            : Small
External RAM size       : 0
Data Stack size         : 512
#include <mega32a.h>
// Alphanumeric LCD functions
#include <alcd.h>
int step=0;
long int rise=0;
long int fall=0;
float pos_dur=0;            //positive duration
float neg_dur=0;           //negative duration
float dc=0;    //duty cycle
// Declare your global variables here
// External Interrupt 0 service routine
interrupt [EXT_INT0] void ext_int0_isr(void)
     if(step==0)
         rise=0;
         step=1;
     if(step==1)
          pos_dur=rise*0.256;    //Positive Duration
          fall=0;
          step=2;
     if(step==2)
          neg_dur=0.256*fall;      //Negative Duration
          step=3;
// Timer 0 overflow interrupt service routine
interrupt [TIM0_OVF] void timer0_ovf_isr(void)
// Place your code here
          rise++;
          fall++;
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port A initialization
// Function: Bit7=In Bit6=In Bit5=In Bit4=In Bit3=In Bit2=In Bit1=In Bit0=In
DDRA=(0<<DDA7) | (0<<DDA6) | (0<<DDA5) | (0<<DDA4) | (0<<DDA3) | (0<<DDA2) | (0<<DDA1) | (0<<DDA0);
// State: Bit7=T Bit6=T Bit5=T Bit4=T Bit3=T Bit2=T Bit1=T Bit0=T
PORTA=(0<<PORTA7) | (0<<PORTA6) | (0<<PORTA5) | (0<<PORTA4) | (0<<PORTA3) | (0<<PORTA2) | (0<<PORTA1) | (0<<PORTA0);
// Port B initialization
// Function: Bit7=Out Bit6=Out Bit5=Out Bit4=Out Bit3=Out Bit2=Out Bit1=Out Bit0=Out
DDRB=(1<<DDB7) | (1<<DDB6) | (1<<DDB5) | (1<<DDB4) | (1<<DDB3) | (1<<DDB2) | (1<<DDB1) | (1<<DDB0);
// State: Bit7=0 Bit6=0 Bit5=0 Bit4=0 Bit3=0 Bit2=0 Bit1=0 Bit0=0
PORTB=(0<<PORTB7) | (0<<PORTB6) | (0<<PORTB5) | (0<<PORTB4) | (0<<PORTB3) | (0<<PORTB2) | (0<<PORTB1) | (0<<PORTB0);
// Port C initialization
DDRC=(0<<DDC7) | (0<<DDC6) | (0<<DDC5) | (0<<DDC4) | (0<<DDC3) | (0<<DDC2) | (0<<DDC1) | (0<<DDC0);
PORTC=(0<<PORTC7) | (0<<PORTC6) | (0<<PORTC5) | (0<<PORTC4) | (0<<PORTC3) | (0<<PORTC2) | (0<<PORTC1) | (0<<PORTC0);
// Port D initialization
DDRD=(0<<DDD7) | (0<<DDD6) | (0<<DDD5) | (0<<DDD4) | (0<<DDD3) | (0<<DDD2) | (0<<DDD1) | (0<<DDD0);
PORTD=(0<<PORTD7) | (0<<PORTD6) | (0<<PORTD5) | (0<<PORTD4) | (0<<PORTD3) | (0<<PORTD2) | (0<<PORTD1) | (0<<PORTD0);
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: 1000.000 kHz
// Mode: Normal top=0xFF
// OC0 output: Disconnected
// Timer Period: 0.256 ms
TCCR0=(0<<WGM00) | (0<<COM01) | (0<<COM00) | (0<<WGM01) | (0<<CS02) | (0<<CS01) | (1<<CS00);
TCNT0=0x00;
OCR0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer1 Stopped
// Mode: Normal top=0xFFFF
// OC1A output: Disconnected
// OC1B output: Disconnected
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=(0<<COM1A1) | (0<<COM1A0) | (0<<COM1B1) | (0<<COM1B0) | (0<<WGM11) | (0<<WGM10);
TCCR1B=(0<<ICNC1) | (0<<ICES1) | (0<<WGM13) | (0<<WGM12) | (0<<CS12) | (0<<CS11) | (0<<CS10);
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer2 Stopped
// OC2 output: Disconnected
ASSR=0<<AS2;
TCCR2=(0<<PWM2) | (0<<COM21) | (0<<COM20) | (0<<CTC2) | (0<<CS22) | (0<<CS21) | (0<<CS20);
TCNT2=0x00;
OCR2=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=(0<<OCIE2) | (0<<TOIE2) | (0<<TICIE1) | (0<<OCIE1A) | (0<<OCIE1B) | (0<<TOIE1) | (0<<OCIE0) | (1<<TOIE0);
// External Interrupt(s) initialization
// INT0: On
// INT0 Mode: Any change
// INT1: Off
// INT2: Off
GICR|=(0<<INT1) | (1<<INT0) | (0<<INT2);
MCUCR=(0<<ISC11) | (0<<ISC10) | (0<<ISC01) | (1<<ISC00);
MCUCSR=(0<<ISC2);
GIFR=(0<<INTF1) | (1<<INTF0) | (0<<INTF2);
// USART initialization
// USART disabled
UCSRB=(0<<RXCIE) | (0<<TXCIE) | (0<<UDRIE) | (0<<RXEN) | (0<<TXEN) | (0<<UCSZ2) | (0<<RXB8) | (0<<TXB8);
// Analog Comparator initialization
// Analog Comparator: Off
// The Analog Comparator's positive input is
// connected to the AIN0 pin
// The Analog Comparator's negative input is
// connected to the AIN1 pin
ACSR=(1<<ACD) | (0<<ACBG) | (0<<ACO) | (0<<ACI) | (0<<ACIE) | (0<<ACIC) | (0<<ACIS1) | (0<<ACIS0);
SFIOR=(0<<ACME);
// ADC initialization
// ADC disabled
ADCSRA=(0<<ADEN) | (0<<ADSC) | (0<<ADATE) | (0<<ADIF) | (0<<ADIE) | (0<<ADPS2) | (0<<ADPS1) | (0<<ADPS0);
// SPI initialization
// SPI disabled
SPCR=(0<<SPIE) | (0<<SPE) | (0<<DORD) | (0<<MSTR) | (0<<CPOL) | (0<<CPHA) | (0<<SPR1) | (0<<SPR0);
// TWI initialization
// TWI disabled
TWCR=(0<<TWEA) | (0<<TWSTA) | (0<<TWSTO) | (0<<TWEN) | (0<<TWIE);
// Alphanumeric LCD initialization
// Connections are specified in the
// Project|Configure|C Compiler|Libraries|Alphanumeric LCD menu:
// RS - PORTB Bit 0
// RD - PORTB Bit 1
// EN - PORTB Bit 2
// D4 - PORTB Bit 4
// D5 - PORTB Bit 5
// D6 - PORTB Bit 6
// D7 - PORTB Bit 7
// Characters/line: 16
lcd_init(16);
// Global enable interrupts
#asm("sei")
while (1)
      if(pos_dur!=0&&neg_dur!=0)
          dc=pos_dur/(pos_dur+neg_dur);
          PORTC=dc;
I've not examined your code at any great length, however one possible issue is the implementation of consecutive if conditional structures you've coded in the ISR.
     if(step==0)
         rise=0;
         step=1;
     if(step==1)
          fall=0;
          step=2;
     if(step==2)
          step=3;
The current implementation consecutively tests each of the if conditional tests and then executes their contained statements if true when the ISR is called. Most likely, they should have been written using the if, else if structure, rather than individual if conditional structures.
Doing so would allow only the statements contained in the first if conditional test which was true to be executed, rather than all three in consecutive cascading order.
The situation which currently exists, on first call of the ISR, step = 0 which then executes the first if(step==0) conditional test which is true, sets step = 1, then executes the second if(step==1) conditional test, which is now also true, sets step = 2, which then executes the third if(step==2) conditional test, which is now also true, sets step = 3 and then exits the ISR.
You've implemented a cascading if conditional structures.
Perhaps you intended on the following:
     if(step==0)
         rise=0;
         step=1;
     [COLOR="#FF0000"]else[/COLOR] if(step==1)
          fall=0;
          step=2;
     [COLOR="#FF0000"]else[/COLOR] if(step==2)
          step=3;
Notice the addition of the else keywords highlighted in RED.
The modified version treats all of the if, else if as a single conditional structure allowing the contents contained in only one of the if conditional statements which first tests true to be executed each time the ISR is called.
BigDog
You could also use
switch(step){
   case 1:
        break;
Wha is the purpose of this code?
DDRA=([SIZE=2][COLOR="#FF0000"]0<<DDA7[/COLOR][/SIZE]) | (0<<DDA6) | (0<<DDA5) | (0<<DDA4) | (0<<DDA3) | (0<<DDA2) | (0<<DDA1) | (0<<DDA0);
(and every other attempt to shift zero)
This is auto set of codevision and i didn't set that.
I did that bigdog but this code still not work.
It was never implied that it was the only issue, only it was certainly an issue.
Stating only that:
... i don't get result.
Or:
... this code still not work.
Does not give those attempting to advise you much to go on.
What is the intended method of reading the calculated value?
What values is the code currently outputting?
At this point, the output method of the obtained value is unclear. There appears to be some attempt at initializing an LCD, however there appears to be no attempt at outputting any value to it.
lcd_init(16);
Another possible issue, is that currently your code is outputting the value of a float type, dc, to PORTC, which seems to make little sense.
       [COLOR="#FF0000"]PORTC=dc;[/COLOR]
I would suggest ensuring your output method is functioning properly and is producing a readable/understandable format, before attempting to troubleshoot your duty cycle measurement algorithm.
Also, as the ATMEGA32A timers do offer a capture feature, it's unclear as to the benefit of your measurement algorithm. There is a reason such features are referred to as "timer/counter" as one of their primary purposes is to time the duration of an external event.
Configuring a timer to periodically to trigger an ISR to then increment counter variables and to then to use these counter variables to time an external event, seems a bit convoluted in this case.
I would suggest reviewing the ATMEGA32A datasheet, you might find some more direct methods of accomplishing the desire task.
As I examine your code, I'm left with more questions than answers.
BigDog
First when a pulse come with positive edge we go into SIR and then we calculate time of this rise to time of fall and then multiply it by 0.256(time for 1 count) now we have positive duration of signal in the same way we obtain negative duration then division pos duration by (pos duration+neg duration) and we obtain Duty Cycle of signal.
Now my Program has no output when i using signal with 50 Hz and 50% dutycycle.
From what means are you obtaining this output? It's unclear at this point after examining your code.
Please reexamine my previous post, as I have added additional comments.
Zip and post your complete CodeVisionAVR project files.
Here is Files and Simulation:
  • Panda123AVR.rar
I found my error but i have new problem!i want to divide a/(a+b) and this is less than 1 i tried to define float a and b but problem exist yet.what do i do for this problem?
Are you attempting to convert the final value to an integer?
If so you could multiply the a/(a+b) by a fixed value like 1000 which would move the decimal point to the right and when the value is assigned to variable of type integer, only the integer part would remain.
BigDog
thanks i do this and it is ok in simulation!but i have new problem in reality!!:|
My microcontroller (ATMEGA32A) don't do anything!I think it can't drive elements.but i don't know what is real problem.
HELP ME:!
This is picture of my circuit:
This displays some value on LCD but it is not correct.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
299
300
301
302
303
304
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
[url]http://www.hpinfotech.com[/url]
Project :
Version :
Date    : 6/19/2015
Author  :
Company :
Comments:
#include <delay.h>
#include <stdio.h>
#define _LCD_FIRST_ROW          0x80     //Move cursor to the 1st row
#define _LCD_SECOND_ROW         0xC0     //Move cursor to the 2nd row
#define _LCD_THIRD_ROW          0x94     //Move cursor to the 3rd row
#define _LCD_FOURTH_ROW         0xD4     //Move cursor to the 4th row
#define _LCD_CLEAR              0x01     //Clear display
#define _LCD_RETURN_HOME        0x02     //Return cursor to home position, returns a
                                         //shifted display to its original position.
                                         //Display data RAM is unaffected.
#define _LCD_CURSOR_OFF         0x0C     //Turn off cursor
#define _LCD_UNDERLINE_ON       0x0E     //Underline cursor on
#define _LCD_BLINK_CURSOR_ON    0x0F     //Blink cursor on
#define _LCD_MOVE_CURSOR_LEFT   0x10     //Move cursor left without changing
                                         //display data RAM
#define _LCD_MOVE_CURSOR_RIGHT  0x14     //Move cursor right without changing
                                         //display data RAM
#define _LCD_TURN_ON            0x0C     //Turn Lcd display on
#define _LCD_TURN_OFF           0x08     //Turn Lcd display off
#define _LCD_SHIFT_LEFT         0x18     //Shift display left without changing
                                         //display data RAM
#define _LCD_SHIFT_RIGHT        0x1E     //Shift display right without changing
                                         //display data RAM
#define EN_DELAY 100
#define LCD_STROBE {LCD_EN = 1; delay_us(EN_DELAY); LCD_EN = 0; delay_us(EN_DELAY);};
#define LCD_RS PORTB.0
#define LCD_EN PORTB.2
#define LCD_D4 PORTB.4
#define LCD_D5 PORTB.5
#define LCD_D6 PORTB.6
#define LCD_D7 PORTB.7
#define LCD_RS_Direction DDRB.0
#define LCD_EN_Direction DDRB.2
#define LCD_D4_Direction DDRB.4
#define LCD_D5_Direction DDRB.5
#define LCD_D6_Direction DDRB.6
#define LCD_D7_Direction DDRB.7
int step = 0;
long int rise = 0;
long int fall = 0;
float pos_dur = 0;            //positive duration
float neg_dur = 0;           //negative duration
float dc = 0;    //duty cycle
char str[23];
    switch(step) {
      case 0:
            rise = 0;
            break;
      case 1:
            pos_dur = rise * 0.256;
            fall = 0;
            break;
      case 2:
            neg_dur = 0.256 * fall;
            break;
    step++;
    if(step == 3)step = 0;
          rise++;
          fall++;
void LCD_Cmd(char out_char) {
    LCD_RS = 0;
    LCD_D4 = (out_char & 0x10)?1:0;
    LCD_D5 = (out_char & 0x20)?1:0;
    LCD_D6 = (out_char & 0x40)?1:0;
    LCD_D7 = (out_char & 0x80)?1:0;
    LCD_STROBE
    LCD_D4 = (out_char & 0x01)?1:0;
    LCD_D5 = (out_char & 0x02)?1:0;
    LCD_D6 = (out_char & 0x04)?1:0;
    LCD_D7 = (out_char & 0x08)?1:0;
    LCD_STROBE
    if(out_char == 0x01)delay_ms(2);
void LCD_Chr(char row, char column, char out_char) {
    switch(row){
        case 1:
        LCD_Cmd(0x80 + (column - 1));
        break;
        case 2:
        LCD_Cmd(0xC0 + (column - 1));
        break;
        case 3:
        LCD_Cmd(0x94 + (column - 1));
        break;
        case 4:
        LCD_Cmd(0xD4 + (column - 1));
        break;
    LCD_RS = 1;
    LCD_STROBE
    LCD_EN = 1;
    LCD_STROBE
void LCD_Chr_Cp(char out_char) {
    LCD_RS = 1;
    LCD_STROBE
    LCD_EN = 1;
    LCD_STROBE
void LCD_Init() {
    LCD_RS = 0;
    LCD_EN = 0;
    LCD_D4 = 0;
    LCD_D5 = 0;
    LCD_D6 = 0;
    LCD_D7 = 0;
    LCD_RS_Direction = 1;
    LCD_EN_Direction = 1;
    LCD_D4_Direction = 1;
    LCD_D5_Direction = 1;
    LCD_D6_Direction = 1;
    LCD_D7_Direction = 1;
    delay_ms(30);
    LCD_D4 = 1;
    LCD_D5 = 1;
    LCD_D6 = 0;
    LCD_D7 = 0;
    LCD_STROBE
    delay_ms(10);
    LCD_D4 = 1;
    LCD_D5 = 1;
    LCD_D6 = 0;
    LCD_D7 = 0;
    LCD_STROBE
    delay_ms(10);
    LCD_D4 = 1;
    LCD_D5 = 1;
    LCD_D6 = 0;
    LCD_D7 = 0;
    LCD_STROBE
    delay_ms(10);
    LCD_D4 = 0;
    LCD_D5 = 1;
    LCD_D6 = 0;
    LCD_D7 = 0;
    LCD_STROBE
    delay_ms(10);
    LCD_Cmd(0x28);
    LCD_Cmd(0x06);
void LCD_Out(char row, char col, char *text) {
    while(*text)
         LCD_Chr(row, col++, *text++);
void LCD_Out_Cp(char *text) {
    while(*text)
         LCD_Chr_Cp(*text++);
void main(void)
TCNT0=0x00;
OCR0=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
ASSR=0<<AS2;
TCNT2=0x00;
OCR2=0x00;
// INT0: On
// INT1: Off
// INT2: Off
MCUCSR=(0<<ISC2);
// USART disabled
SFIOR=(0<<ACME);
// ADC disabled
// SPI disabled
// TWI disabled
// RS - PORTB Bit 0
// RD - PORTB Bit 1
// EN - PORTB Bit 2
// D4 - PORTB Bit 4
// D5 - PORTB Bit 5
// D6 - PORTB Bit 6
// D7 - PORTB Bit 7
#asm("sei")
LCD_Init();
LCD_Cmd(_LCD_CURSOR_OFF);
LCD_Cmd(_LCD_CLEAR);
LCD_Out(1,1,"Duty Cycle");
while (1)
      if((pos_dur != 0) && (neg_dur != 0))
          dc = pos_dur / (pos_dur + neg_dur);
          sprintf(str, "%5.2f", dc);
          LCD_Out(2,1,str);
As I do not see a crystal and its associated caps, I will assume you are using the internal RC oscillator which normally ships from the factory enable with a clock frequency configure for 1MHz.
Assuming the above is correct, the most likely culprit is the watchdog timer which typically must be disable manually.
If the watchdog timer is not disable or periodically reset, known as "kicking the dog," the device will repeated reset itself.
I reviewed the CodeWizard generated configuration settings in your code and I do not see any indication the watchdog timer has been disabled.
To disable the watchdog timer manually, you must simultaneously write a logic '1' to both the WDTOE and WDE bits of the WDTCR register, consult your compiler/IDE/CodeWizard documentation for the specifics in your case, the CodeWizard maybe able to generate the necessary code to achieve this task.
Example:
WDTCR = 0x18;
BigDog
Ok,this problem was solved.but i have still another problem seven segments refresh very fast and i can't see true number what i should do?
Post your current code, also posting a schematic of the circuit would be helpful.
You can use the Insert Image button, tree with a crop marks, to post the image of a schematic.
BigDog
What problem was solved ? Did you get the duty cycle on LCD ? If yes, how did you solve the problem. Post your working code. There is no code related to 7 Segment display in your code. What do you expect the 7 segment to do ?
In simulation My program works good but in real don't show real Temp.i use SMT-160 sensor and this is my code what is wrong?
PHP:
Project :
Version :
Date    : 6/20/2015
Author  :
Company :
Comments:
#include <stdio.h>
#include <delay.h>
#include <alcd.h>
long int pos=0;
long int pos_dur=1;
long int neg_dur=1;
long int neg=0;
int step=0;
int yekan=0;
int dc=1;
float f=0;
float n=0;
int dahgan=0;
float p=0;
int temp=0;
void display(int a);
void display2(int a);
int counter=0;
    if(counter!=100)
if(step==0)
    pos=0;
    step=1;
    else if(step==1)
         neg=0;
         pos_dur=pos;
         step=2;
    else if(step==2)
    neg_dur=neg;
       step=0;
       counter++;
        pos++;
        neg++;
void main(void)
DDRB=0xFF;
DDRC=0xFF;
TCNT0=0x00;
OCR0=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
ASSR=0<<AS2;
TCNT2=0x00;
OCR2=0x00;
// INT0: On
// INT1: Off
// INT2: Off
MCUCSR=(0<<ISC2);
// USART disabled
SFIOR=(0<<ACME);
// ADC disabled
// SPI disabled
// TWI disabled
// RS - PORTA Bit 0
// RD - PORTA Bit 1
// EN - PORTA Bit 2
// D4 - PORTA Bit 4
// D5 - PORTA Bit 5
// D6 - PORTA Bit 6
// D7 - PORTA Bit 7
lcd_init(16);
#asm("sei")
while (1)
          PORTC.7=1;
          if(PORTD.0==1)
           counter=0;
           p=pos_dur;
           n=neg_dur;
             f=(pos_dur)*1000;
             f=f/(pos_dur+neg_dur);
             dc=f/10;
    //  sprintf(st,"%d __ %d :",dc,pos_dur);
     // lcd_gotoxy(0,0);
       // lcd_puts(st);
     // sprintf(st2,"%d",neg_dur);
     // lcd_gotoxy(0,1);
       // lcd_puts(st2);
       temp=100*dc-3200;
       temp=temp/47;
        if(temp<10)
         display(temp);
        else if(temp>=10)
           dahgan=temp/10;
           display2(dahgan);
           yekan=temp-10*dahgan;
           display(yekan);
void display(int a)
       switch (a) {
    case 0:
    PORTC=0b00111111;
    break;
    case 1:
    PORTC=0b0110000;
    break;
    case 2:
    PORTC=0b1011011;
    break;
    case 3:
    PORTC=0b1001111;
    break;
    case 4:
    PORTC=0b1100110;
    break;
    case 5:
    PORTC=0b1101101;
    break;
    case 6:
    PORTC=0b1111101;
    break;
    case 7:
    PORTC=0b0000111;
    break;
    case 8:
    PORTC=0b1111111;
    break;
    case 9:
    PORTC=0b1101111;
    break;
       switch (a) {
    case 0:
    PORTB=0b00111111;
    break;
    case 1:
    PORTB=0b0110000;
    break;
    case 2:
    PORTB=0b1011011;
    break;
    case 3:
    PORTB=0b1001111;
    break;
    case 4:
    PORTB=0b1100110;
    break;
    case 5:
    PORTB=0b1101101;
    break;
    case 6:
    PORTB=0b1111101;
    break;
    case 7:
    PORTB=0b0000111;
    break;
    case 8:
    PORTB=0b1111111;
    break;
    case 9:
    PORTB=0b1101111;
    break;
