What's the relation between dB and dBm?
arunapai
Junior Member level 2
Whats the relation between dB and dBm?
Re: dB and dBm
I ve another doubt here.. My spec says that signal should be within 16dBm(+-3dB).
Is this correct?
Re: dB and dBm
xdB = 10 log (Pout / Pin ) used to measure power gain
xdB = 10 log ( P / 10^-3 ) used to measure power
Re: dB and dBm
Actualy I think it depends on what do you refer to, power or voltage. For power it is as the_risk_master said, but for voltage it is:
20*log(Vout/Vin) for dB, and 20*log(V/0.77) for dBm, not sure for 0.77!
And another thing, xdB = 10 log (P) is not true for one thing, P is in watts so it has to be devided by watts so we could use log()... It should be 10*log(Pout/Pin)...
For the second question, I am not sure what is your question, but I can help you this way:
10*log(P/1mW)=16 => P=1mw*10^(1.6)≈39.8mW this may mean that your signal must be at least 39mW...
Re: dB and dBm
Your signal must be larger than 13dBm and smaller than 19dBm That is how it is !
Re: dB and dBm
16dbm+3db=19dbm
Re: dB and dBm
Hello arunapai,
Go through the attached nice PDF document on "dB Everything you ever wanted to know about decibels but were afraid to ask…"....
---manju---
Re: dB and dBm
16dBm +-3dB
I have probably written it that way (dBm +-dB) a thousand times and never realized that it was possibly not technically accurate :!:
Maybe 16dBm +-3dBm :?:
13dBm ~= 20mW
19dBm ~= 79mW
You can convert that into E or I based on the load
:idea:
dB is an expression of the power ratio between any two signals.
dBm ( sometimes called dBmW )has one of the signals to reference built in: 1 milliwatt and is therefore a measure of signal level. So 0dBm = 1mW.
2mW = 10xlog10(2) ~ 3dBm.
If you work it backwards you can prove that there is a square relationship between power and voltage or current which is equal to 2 x log of a number. Therefore if the ratio is in voltage or current then the formula is 20 x log(ratio).
A 'Bell' unit was too large ( like a Farad ) so they used 1/10 of a Bell or a decibel. If I remember right, it was Alexander Bell of the Telephone fame that described the exponential relationship between the power in an audio signal and it's apparent loudness.
Re: dB and dBm
Simple relation between dB and dBm is:
1dB= 1dBm+30
Hope it helps you.
Regards
