munzir
Full Member level 6
What's the problem inside the Air Compressor ?
Model : GA11FF Workplace Air System (Atlas Copco)
Loading pressure : 7 bar to 8 bar
Loading Amps (Max) : 25 Amps
Unloading pressure : 8 bar to 7 bar
Unloading Amps (Max) : 12.5 Amps
Loading and unloading process takes less than 30 seconds.
The problem is that sometimes while unloading the electronic display shows the message "program stopped " nearly around 7.7 bar and keeps on unloading till 7.4 bar and then displays the message that " motor stopped" and really the motor stops for a while and as the pressure drops to 7 bar the motor and the system starts working fine and starts loading .
Motor Rated FLA is 35 Amps , 3 phase 380 to 400 V ac , supply
What might be the problem ?
thanks
thanks
