Register Log in
What's the maximum range of LPG gas detector?
uwak
Newbie level 1
wat is the maximum range of gas detector in order to detect gas..
thnx guys..
RF-OM
Advanced Member level 2
The Earth
Re: gas detector..
What range you are talking about? Distance from gas leakage point or concentration and what kind of gas?
uwak
Newbie level 1
Re: gas detector..
an LPG detector.. distance from the detector to the gas leak..
- thnx..
- uwak -
FvM
Super Moderator
Staff member
Bochum, Germany
gas detector..
The sensitive of gas detectors is in concentration units (particularly % LEL) for combustible gas detection. The concentration depends on leak rate and ventilation situation, another important point is gas density. LPG always accumulates at the bottom of an air volume respectively a room's floor.
A sensor can be either mounted at the position where the highest concentration is expected or near to a possible ignition source.
RF-OM
The Earth
Re: gas detector..
I agree with LvM and I think you need to check safety gas leakage monitors. There are many available on the market and LPG is relatively easy case.
Toggle Sidebar
