What's the function of Ripple Blanking I/O and LT pin on the 7447 BCD decoder IC?
D
darrenbkl
Hi all,have a question here is that,what is the function RBI,RBO and LT pin on the 7447 BCD-7segent decoder IC? It seems to suppressed zero on the 7 segment display,but I don't know how it works. About the LT, I only know has to connect to VCC, can anyone explain me? thx : )
ripple blanking
LT is a LAMP TEST input. It's active low so when at logic level 1, it has no effect; when at logic level 0, every output is active so you can check if a segment or an output is broken.
RBI is RIPPLE BLANKING INPUT is used in multi-digit display and should be connected to the RBO of the previous digit (the digit to the left). In this way, you may avoid showing trailing "0" if not needed as you do in manual number writing. In this way, for example, the multidigit number "00123" will show as "__123" while "02034" will show as "_ 2034" (where "_" is to be intended as an off digit). This trick was in use when digital circuits were not so intelligent as now with microcontrollers.
ripple blanking output
cool,thx. I m a newbie in electronic stuff,currently still doing flip flop and counter : (
I try to connect a 7490 counter --- 7447 --- 7 segment display using multisim,it works. But why when i switch on the circuit, the display appear unstable? I mean when the display change from a number to the other, let's say from 4 to 5, in between transition there is some unstable state of the display. is it cause by propagation delay of the serial ripple counter connection?
ripple-blanking
Don't think so. Propagation time in standard TTL is very fast. Maybe some pin left open even if in TTL logic, an unconnect pin should be read as '1'.
Try posting the schematic.
ripple-blanking input
The circuit seems basically correct.
Just some note:
* the clock frequency of 1kHz is very high for a display. You'll be unable to see the number changing. Try with much lower frequency like 1 or 2 Hz
* the BI/RBO pin is a strange input/output pin. Leave it unconnected
* try the same with LT and RBI. In TTL logic (like LS family), an unconnected pin is equivalent to a logic "1" (but this is not true for CMOS logic where every pin mus be connected to a secure digital level)
* in the real circuit, put a 0.1uF bypass ceramic capacitor as near as possible to the poer pins of the device
7490 schematic
wat does the 0.1uF cap do? u mean place it near "power" pin?
7447 multisim example vcc pin
Yes, sorry ... I meant "power" pins.
In real-world circuits, it's suggested to put a 0.1uF capacitor between VDD and VSS of a device every few device to filter high frequency noise generated by fast switching logic devices.
ripple blanking
A clock pulse with 1kHz frequency,which is a 50% duty cycle square, that means the period of the wave is 1ms right? But 1 pulse is consist of a high and low , or high and low are consider as a pulse separately?
