irata
Junior Member level 3
I have this Diode Bridge in an analog front-end circuit, I want to know what does this Diode bridge do, and why there is such a diode brigde in the signal path.
thanks very much!
thanks very much!
pankajdudulwar said:I suppose that it is the level shifter.Apply the KVL with the signal level ur getting and just solve the equation u will find that ur signal is DC shifted. Please tell us were ur using this cct i.e infront of which analog cct.
Added after 54 minutes:
I simulated the above cct with signal input as 2 Vp and 250mVp. I cam to the conclsion that it might be used for the isolation purpose. If u tell me where ur using this cct then I can get the real thing.
Thank you,
