chengyh
Newbie level 2
Re: what's the difference between "DIFF" and "
"DIFF" defines the active region, in th fabrication, which material does it diffuse? or nothing to do.
The iorn implant is defined by the "NIMP" or "PIMP" , whose area is bigger than the "DIFF" defined. The question is :what's the resoult of the area whic inside the "NIMP" or "PIMP" but outside the "DIFF"?
Added after 29 minutes:
I think, "DIFF" define the area of active region that is the region needed implant with n+ or P+ iorn according the nmos or pmos, while the "NIMP" or "PIMP" defince the area to implant which of course should be larger than the area of "NDIFF". is it right?
chengyh said:"DIFF" defines the active region, in th fabrication, which material does it diffuse? or nothing to do.
