giggs11
Member level 3
hi,
I'm quite quizzed about the difference between Clock Buffering, CTS and Clock Trees. This is what I vaguely understand:
Clock Buffering refers to insertion of stages of buffers to drive the heavy load of the clock signal. Confined to a relatively small module.
CTS involves symmetric routing of the clock signal to the various modules in a system design. The idea is to connect the clock signal symmetrically to all modules in the system to avoid clock skew due to wire capacitance. Buffering is also done at this stage to drive the load of the clock signal to all modules in design.
Clock trees refers to the tree-structure adopted in CTS to distribute the clock.
Please comment on these definitions. Is it also possible to design till tape-out without performing Clock Analysis. What is the main effect of such leaving out the clock analysis stage.
Thanks.
Thanks.
