What to do when the value of Vgs is unknown?
suhas_shiv
Full Member level 2
Full Member level 2
Value of Vgs
When designing, say, a current mirror, you find the value of R and W/L. But you have to know the value of Vgs for that. Usually, in any book, Vgs is assumed to be some value for a particular technology. How do you actually design if the approximate value of Vgs(for a particular technology) is not known( Vgs depends on biasing also)?
Thanks
paulux
Full Member level 1
Re: Value of Vgs
There is no general rule for designing Vgs and it depends on your application. In low Vdd application, you try to minimize Vgs. If it operates at saturation region, Vgs>=0.2V. Just an example, this absolutely depends on process technology
jluhzw
Member level 5
Member level 5
Hangzhou China
Re: Value of Vgs
I gree with paulux.there is no absolute way.It depends on your applications and your fab technology.
xerxer
Junior Member level 3
Re: Value of Vgs
you may try to set up a simple circuit to simulation the vgs using hspice or pspice .
i think the method probobly help you to get you vgs .THis is just an advice
