Feb 3, 2010 #1 jitendravlsi Full Member level 2 Joined Jul 21, 2008 Messages 132 Helped 8 Reputation 16 Reaction score 5 Trophy points 1,298 Activity points 2,136 Please tell me what to check before starting the floorplan in soc encounter and how to check them?
Feb 3, 2010 #2 A arjun1110 Advanced Member level 4 Joined Jul 3, 2008 Messages 101 Helped 27 Reputation 54 Reaction score 16 Trophy points 1,298 Location Bangalore,India Activity points 1,865 Import the gate level verilog netlist , SDC and check the timing by running "check_timing" command. Which will give you the rough timing, missing timing constraints if any in the SDC etc...
Feb 3, 2010 #3 jitendravlsi Full Member level 2 Joined Jul 21, 2008 Messages 132 Helped 8 Reputation 16 Reaction score 5 Trophy points 1,298 Activity points 2,136 by using the "checkDesign" command in soc encounter we can check check for the following data: Physical library Timing library Netlist I/Os Tie-high and tie-low pins Power and ground pins but i dont know how to check timing parameters or we can say sdc.. Dear arjun are you sure about this command in soc encounter?
Feb 3, 2010 #4 A arjun1110 Advanced Member level 4 Joined Jul 3, 2008 Messages 101 Helped 27 Reputation 54 Reaction score 16 Trophy points 1,298 Location Bangalore,India Activity points 1,865 Hi Jitendra, I have uploaded timing closure in soc encounter document. Go through "Data preparation section I guess which will answer your questions". Let me know if you still have any doubts. Regards
Feb 4, 2010 #5 jitendravlsi Full Member level 2 Joined Jul 21, 2008 Messages 132 Helped 8 Reputation 16 Reaction score 5 Trophy points 1,298 Activity points 2,136 thanks arjun..... really helpful doc
